Stated out half chock than full chock. no gas getting carb. I have replace fuel lines, fuel pump and filter also spark plugs
I had a similar problem with a snow blower. If there is no gas getting to the carb there may be some junk in the tank plugging the line. Disconnect the line from the first item from the tank (filter or pump). Blow back through the line with a hand pump or LOW pressure air supply and see if the fuel starts flowing.
I'm sure you have dirt in your carb. If you know how to take the carb apart......You need to get a can of carb cleaner and carb kit. Take the carb apart and spray every hole and nook a crany you can see. Put the new kit in the carb and you should be ready to go!! This has happened to several times.
