Apple iPhone Smartphone Logo
M
Monty hued Posted on Feb 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to block unknown number on my iphone5 - Apple iPhone Smartphone
Jesse Allen
Level 3:
Master:
  • Apple Master 307 Answers
  • Posted on Mar 26, 2018
Jesse Allen
Apple Master
Level 3:
Master:
Answers
307
Questions
0
Helped
161067
Points
1872
You can block a number that had called you before. In the Phone app, tap on Recents, find the number you want to block and tap on the "i" icon on that number. Scroll down and tap Block this Caller. Or you can go to Settings>Phone>Blocked and tap on Add New to add a number to the block list. Here's a more detailed guide on blocking a number on iPhone: How to Block Numbers on iPhone and Find Blocked Numbers on iPhone Hope it helps.
Richard Nagy
Level 2:
New Friend:
  • Expert 44 Answers
  • Posted on Mar 06, 2015
 Richard Nagy
Expert
Level 2:
New Friend:
Answers
44
Questions
Helped
4287
Points
102
You can not block unknown numbers, however there is a block list for numbers that bother you! Settings>Phone>Blocked
2answers
Block unknown callers from Iphone 5s phone.
Call your provider they can add a feature so no private calls go through without them adding a *.. Before your number to show there number.
Apr 12, 2017 • Cell Phones
2answers
How do i find out a blocked number thats been cranking me on my I phone 6
You should be able to block unknown numbers. Right now I don remember how to do it since I haven work with an iPhone for a long, long time. Also check to see if there is any app that can block spam and unknown numbers.
But give this a try.
  • From iPhone App: Goto Recents Tab-> tap "i" next to number you want to block-> scroll to bottom & choose "block this caller".
Jul 11, 2016 • Cell Phones
1helpful
2answers
I want to stop unknown numbers calling my iphone5
Go to recent calls, then info on that call. Use the copy feature on "Unknown Caller". Then go to Contacts, touch + to add a new contact. Use the paste feature for the following: first name, last name, company, phone number. Touch done and you will see an option to block caller. Then in Settings you can go to your Phone, Blocked, and you should see it listed alphabetically with any others you may have. I have an iPhone 5 with iOS 7.0.6. Good luck
2answers
Too stop unknown numbers calling free
Unknown callers should have a number that appears with no name - these can be blocked post call or in the Settings/Phone/Blocked Callers section. Unknown calls with no number can only be blocked from the carrier side - you would have to contact your provider.
I WOULD LIKE TO KNOW IF I CAN DELETE ALL THE CONTACTS IN MY BLOCKED LIST PERMANENTLY FROM MY DEVICE
Your question is a little bit confusing but let me try to understand the goal you wish to achieve: i believe you dont want to receive calls or messages from some numbers in your contact list. If thats the case and you have already added them to the block list then you dont have to delete these numbers. Let them stay in the blocked list and you wont be able to receive any call from these numbers. However of its someone who is stalking you then he or she may use a different number, in that case your best bet is to change your number.
2answers
Hopw do you block certain phone numbers from calling your iphone5?
Most carriers offer this service. I know that verizon lets you set the numbers yourself through my verizon, but a quick log on to your online account should present the option to set blocked numbers.
2helpful
Pantechhow to block a unknown caller on my p2030 pantech cell phone
    • 1 Press "*60," then press "#" on the keypad. Wait for a dial tone.
    • 2 Dial the phone number you want to block, the press the "#" key.
    • 3 Repeat steps 1 and 2 to add up to six numbers to the block list.
1helpful
How to block an unknown number in nokia E-5
Here's a handy little application that you can purchase for your phone that will allow you to block unknown numbers.
http://nokia-e5-00-software.epocware.com/Handy_Blacklist.html
May 04, 2011 • Cell Phones
3helpful
3answers
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
