Here are the wire placements for the switch of a DeWalt DWD520 hammer drill:
The red wire from the motor goes to the top left terminal on the switch.
The black wire from the motor goes to the top right terminal on the switch.
The white wire from the power cord goes to the bottom left terminal on the switch.
The black wire from the power cord goes to the bottom right terminal on the switch.
It's always recommended to double-check the manual or contact DeWalt customer service for confirmation, as wire placement may vary depending on the specific model and year of manufacture.
look for a positive or negative + or - sign on the whitch kit. Wires the terminal and now your cord is attached to the tool dewalt dw 660 you are good to go. I add a diagram that may help you good luck.
Have you removed the old cord yet, if not make a crib sheet showing where the wires go. If the wires push into the switch use a staple and bend one of the long ends and push into hole and when pushing gently pull the cord wire out. Let me know if you need any other help
I have fix my dewalt dw 056 with a switch comming from an old dewalt hammer drill that i had lying around if you find and older dewalt hamme drill with burn brushes u can interchange the switch ,they sell the repalcement new switch for around $56.00 here in canada its not worthed u can get a new refurbish dewalt impact for around $99.00 from toolking
You can download the .pdf manual for the DW120 from here. and see an exploded parts view & list here. That should get you working in short order.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
dbx is a family of noise reduction systems developed by the company of the same name. The most common implementations are dbx Type I and dbx Type II for analogtape recording and, less commonly, vinyl LPs. A separate implementation, known as dbx-TV, is part of the MTS system used to provide stereo sound to North American and certain other TV systems. The company – dbx, Inc. – was also involved with Dynamic Noise Reduction (DNR) systems.
My conclusion is that your answer was right on.... good work.
