Computers & Internet Logo
A
Anonymous Posted on Mar 01, 2015
I have an IT works wireless mouse but i dont have a pairing code,can i get a generic one?
Sheldon Dedek
Level 3:
  • Master 912 Answers
  • Posted on Mar 01, 2015
Sheldon Dedek
Master
Level 3:
Answers
912
Questions
0
Helped
306553
Points
3298
A generic code used by keyboards, nice, headsets, etc is 0000 or 000000.
Do you have a model number for mouse?
1helpful
Pairing code of Sonay Vaio VGP-BMS21?
Try this
> (Go To) Control Panel > Bluetooth Devices
If your device is already there
Highlight device then in menu bar select Remove Wireless devise
Click on Yes
When device removed or if it was not there in the first place
> Add Wireless Device
When computer finds your device select it
Click on Next
Choose Pair without CODE
Click on Next.
Computer should then install drivers
This works with my Sony VGP-BMS33
Hi, My problem is I can't not pair my NEW 2.4 GHz Wireless Laser Mobile Mouse with my 2.4 GHz dongle. I follow the instructions on the control center, 1 Turn off the mouse. 2 Insert the dongle into an...
I'm sorry for your frustrations, yes, computers can do that.
Im not HP, just some retired dude...
First>.?
batteries good in this new mouse? put in top brand batteries.
some that come with a mouse are (bottom barrel cheap batteries or are really old and bad from long time on a shelf)
then make sure the DEVICE manager shows the mouse as present.
steps, (generic) (your mousemaker.com will have better advice)
1: be connected to the internet is first, (after good batteries)
2: then plug in the mouse & USB dongal,
3: here w7 DINGDONG! sound, and then see it try to do PnP
windows, will attempt to find the correct driver for it on the internet.
and if lucky, ( what mouse did you buy?) the W7 finds it and loads this special driver, be aware there are vast makers of mice.
on mine took like 5min to load a BluTooth driver too,
IF this fails. go to CP, control panel
then click device manager.
then see all devices on your system.
look for bad devices or missing.
red. or yellow is missing <marks there.
so. see this, if you see ANY errors here, fix them all first.
right click any and then pick "update driver software"
make sure no USB errors either. this mouse may take 3 working drivers to work (usb-bluetooth-mouse)!! non trivial that...
mouse-jp1ubqo3j1kmelkhu15mp2bt-1-0.jpg also if the NEW mouse came with? a CD for drivers? ,use that.
2helpful
How to get the pairing code of my microsoft mobile memory mouse 8000?
I have windows vista,
you don't need a pairing code, this is what worked for me:
Go on control Panel -> Hardware and Sound -> Bluethooth Devices, then click on Add Wireless Decive. It will open a window and you will see the mouse there (if you dont' see it, click on the pairing button of your mouse). Then, don't double-click on the icon because it will ask you to enter the pairing code! Instead, right-click on it and choose ''properties''.
It will open the properties, then go to ''Services'', it will search the services you device offers. When the service appears, select the check box. It will install you mouse on your computer!! then click ''OK''.
There you go!
I worked for me, hope this helps!
Goodluck ;)
Pairing code for Microsoft Wireless Laser Mouse 5000
Not really a code, just first press button on top of your receiver and then the button on the bottom of the mouse. The receiver LED should stay green when they are connected. If this does not happen check that you are using IntelliPoint Mouse Software. See more:
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/microsoft-wireless-laser-mouse-5000-v10-model-1058/692bf1f8-ce34-4937-8c8f-a78cff379787?rtAction=1483615029455
2answers
Hi, I have a DELL wireless travel-mouse which works fine on my DELL inspiron, but does not work on my ACER Aspire One netbook - do I need to find a specific driver or will it never work? thanks. David
Wireless mice usually work via radio frequencies commonly referred to as RF.this is also the case with bluetooth technology.so if your mouse is a bluetooth mouse you may need to run the software to make the mouse communicate with your PC.another issue is pairing (coordinating your mouse's transmitter with your mouse's receiver. It requires both parts to operate on the same frequencies, usually by using the same identification code. Pairing takes place to try to eliminate interference. Some devices automatically pair both devices at start up; others need to be manually paired by entering the same codes on both devices.once both devices are paired they will generally communicate with each other.best of luck.
3helpful
2answers
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
I can't operate the mouse. its not working.
Install fresh batteries, turn it on and make sure your bluetooth dongle is installed and active. If you have never paired this mouse with it's receiver, then you will have to put them both into pairing mode, and once paired you should have no problems.
8helpful
4answers
Problem pairing wireless mouse to reciever
HI ALL, Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is the process of coordinating your mouse's transmitter with your mouse's receiver. It requires both parts to operate on the same frequencies, usually by using the same identification code. Pairing takes place to try to eliminate interference. Some devices automatically pair both devices at start up; others need to be manually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteries in mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) and place the batteries. Cover, Now you can see the red light glowing on the bottom of the mouse, now your mouse is ready to pairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE will be ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, if mouse curser is not moving then press BUTTON 2 one time – now defiantly your mouse will work, If you need any other technical support for GMAX, products please contact
Grand Canyon Tech
Grand Canyon Tech
