Squealing is usually belt slip or dry idler roller bearings.
Grinding noises can be a worn main bearing at the back, or the felt front drum slides.
It is a 1996 machine, so probably time to think about replacing it? Diagnosing would involve a full disassembly and check the parts mentioned for wear. This is a UK and Australian model.
Those values and most everything else you need for DIY work are contained in the Haynes manual for your vehicle.
We have one with each of our vehicles and not only give you the info needed to do repairs yourself but also get an idea of how much work a specific repair should (or shouldn't) cost.
'88 Chevy pickup manual
You can also buy these from auto parts stores for a few dollars less and sometimes on eBay for even less.
Bearings (including main bearings) as well as rear main seal require engine removal to do it correctly. If the engine is tired, then get a different one. Otherwise your determination, financial situation and skill level will tell you what you need to do.The entire job is not difficult but takes some time and you need to make precise measurements in order to get it right. (change oil pump with bearing sets) Parts prices can be found at napa online as well as numerous other places. If you need help along the way, someone here will be happy to help!
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
