On the front bottom of the machine there is a plastic 'kick plate' that clips/pushes on. Remove this plate and you will see the filter with a cover secured by a star/phillips screw. Loosen screw and twist this cover off to gain acess. Don't do what i've just done and twist without removing this screw as it breaks it:-(
anyone who knows where i can get a filter cover please post back!
Hi.
The door will not normally open if there is water left in the m.c. check pump, and make sure the belt is o/k, as some hoovers do not let you open the door if the belt has come off. Please leave feedback.
Thanks.
I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
Hi there, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
