If it is connected to WIFI,
Go to settings on your phone, go to connectivity, go to WiFi and then reset your password from there. If your Tablet asks you for a new password, then enter 12345 because that is the default WiFi password for all Android devices. After that, you can enter a new password and re-create your WiFi password.
you will need to set up the wifi first , there is a spot in the setup screens that says wifi , go to this and expand it by clicking on it , this will show a list of avail networks (there could be more than one) select yours in the list , a prompt will show up (enter network password ) you must enter your network password exactly as its in your router (or coffee shop router) and press enter when done , it will prompt back with connecting " when its done it will go back to previous screen , make sure your main prompt for wifi is still on then open your browser and enter a desination it should work , I will tell you this model is very picky about signal strength and wont connect unless you have least four bars .
First of all, you must have the password which is set for your home WIFI. You can't do anything without it. Assuming you got the password, Go to tablet's Settings, turn on WIFI. When your WIFI router is displayed in the list, select it and you will be prompted for the password. Enter the password and click Connect. When you see Connected, it's done.
When entering the password there is a tick box that allows you to save the settings and connect whenever this wifi available, check the settings from the password page!
It sounds as if you simply need to reconnect to your wifi network. If you have already connected to it, but still have no access, then disconnect from your network, remove the network from your settings (Forget The Network) and then try reconnecting to it.
When you reset the tablet your tablet wifi settings, wifi name and password will be erased. You have to detect your wifi on the tablet, connect to it and enter password right?
