Vizio VA19LHDTV10T 19 in. LCD TV Logo
A
Anonymous Posted on Mar 02, 2015
How do I repair my Vizio tv?
VA19LHDTV10T has no picture and no sound just the white vizio logo
Jerry Kramer
Level 3:
  • Vizio Master 3,933 Answers
  • Posted on Mar 02, 2015
Jerry Kramer
Vizio Master
Level 3:
Answers
3933
Questions
Helped
882097
Points
12076
Checking the input is a good idea. This is going to be the button on your remote labeled INPUT or SORCE. The fact that you have the Vizio logo coming up says your screen is good. The other thing I would check are you connections by replacing cables with know working ones.
1helpful
How do I know if I need to replace the main board?
Vizio TV Repair - How to Install Vizio LCD Motherboard ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
Vizio 3632-1512-0150 Main Boards Replacement for ...
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
Vizio TV Repair - E601i-A3 Main Board Replacement for No ...
Why does my sound go off on my tv after watching it for about an hour
That is a problem with the older Vizio tv's. I came to the conclusion that it was cheaper to replace it than to get it fixed.
No picture or sound
Its the main board 90% of the time when a vizio has that symptom.
2helpful
Vizio 19 inch no picture no sound
That capacitor could possibly be the cause. On some sets, the 12V supplies both the video and audio circuits. I would recommend replacing the cap and checking power supply outputs especially the 12vdc supply.
Can't get full screen on Vizio VA19LHDTV10T
This is either due to some incompatibility or change of format of picture. Also the color system should be same like PAL/SECAM etc.
2answers
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
I can hear sounds but no photo on my 19in vizio lcd tv but the scrteen it only stays on for 2-3 seconds but the sound stayes on as long as you want
Take a bright flashlight and place it on the screen. Around the edged of the flashlight see if you can see an image moving around on a good channel. If so you need an inverter/lamp repair/replacement.
My vizio will not turn on. It is not the outlet, because I switched the plug with my DVD player and the player works in both outlets. Is there any way I can reset my TV to make it turn on again?
It may either be your remote sensor on the front of the TV (http://cgi.ebay.com/VIZIO-VA19LHDTV10T-IR-REMOTE-SENSOR-715T3347-/170472611897?pt=LH_DefaultDomain_0&hash=item27b0f5a039)
You can test this by manually switching on the power vs using the remote.
Or it is this part that failed.
http://cgi.ebay.com/VIZIO-VA19LHDTV10T-POWER-SUPPLY-BOARD-PWTV8C21ASA1-/320540436908?pt=LH_DefaultDomain_0&hash=item4aa1b2e9ac
Replacement is pretty straightforward for the power supply, but the eye will require some soldering skills.
My tv stopped working with my DVD player
Call Vizio for a warrenty repair.Ur DVD Combo,the laser eye is dirty,must take the tv aparts and clean it.But it under warrenty,take ur warrenty from Vizio let them take it aparts,can clean it for u.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
