Question about Simpson Washing Machines
My Simpson esprit 650 top loader 6.5 kg washing mashing won't spin
  • Tom Ryan Jun 12, 2019
    Try changing the carbon brushes on the motor
    Genius:
  • Simpson Master
  • 1,585 Answers
Check pump for blockage
Posted on Mar 02, 2015
6ya staff
SOURCE:
Anonymous
SOURCE: Simpson Esprit 650 6.5kg Washing
I have just had the same problem occur with my washer.
I found that the hot would work but the cold would not.
The fault is the cold water valve.
This is the part that the hose screws to at the back of the machine.
To have a look at it unscrew the top of the controls at the back and you will
find the valve.
Follow this link for the part.
http://www.alliedappliance.com.au/info/A864810001.html
Posted on May 21, 2009
Joe Onley
Joe Onley Sr.
  • 363 Answers
SOURCE: my washing machine was running and suddently
probably a hole in the tub or one of the hoses. If you can flip the machine over and look underneath you will probably discover the source of the leak. If it's a hose, you can probably get a new one, but if it is the tub, you need a new machine, it isn't worth the time or effort to replace the tub :(
Joe
Posted on Sep 02, 2009
micabbock
SOURCE: Simpson front loader washing machine repair person
I have Simpson EZI sensor 9.5kg and during the washing i have a EF message coming up.
Posted on Jul 18, 2010
willhoppner
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
luisa_sgro
  • 713 Answers
SOURCE: simpson esprite 650 front loader washing machine.
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Posted on Sep 12, 2010
Testimonial: "Really helpful. Thank you."
I have a simpson esprit 650, won't spin replace the controller motor and still won't spin, any suggestions
What do you mean by the controller motor? This model has a timer and that is often the cause of spin problems but not always. There are other reasons but you need fault finding skills and a test meter to find them. You haven;t told id you have either,
Oct 30, 2017 | Simpson Washing Machines
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
Hi, Weve got a simpson esprit 700 washing machine and the cold water tap seems to be blocked. I've disconnected the hose at the washing machine end but when I've turned it on in the sink it works fine so...
Hi just read your posting.There are 2 types of SIMPSON ESPRIT washing machines,There is a top and front loader version.Which one is yours?Please reply and I will guide you on replacing the water valve.Looking forward to your reply.
Sep 19, 2010 | Washing Machines
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Sep 12, 2010 | Washing Machines
Main power flicks off when starting my simpson esprit 750 washing machine
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Aug 28, 2010 | Washing Machines
Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Dec 27, 2009 | Washing Machines
Dec 21, 2009 | Washing Machines
Simpson esprit 450 washing machine top loader
Apr 11, 2009 | Washing Machines
Washing Machines Logo
721 people viewed this question
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
