HP W2371D 23 Full LED Monitor 16:9 5ms 1920x1080 250 Nit 1000:1 DVI/VGA Black - - Retail - B3A19AAABA Logo
A
Anonymous Posted on Mar 03, 2015
Monitor has no sound
How do i turn sound on?
ka4iup
Level 3:
  • HP Master 4,062 Answers
  • Posted on Mar 03, 2015
ka4iup
HP Master
Level 3:
Answers
4062
Questions
0
Helped
1096730
Points
51404
If you monitor has a sound input, connect the cable to your computer. Open the computer sound control and select the monitor speakers (it may be the headphone output for your computer). You do not want to have the computer speaker selected.
How do i get the sound to turn off on the monitor when i turn it on?
Hello Janine
Of course, if your particular monitor provide sound, (integrated) or the monitor has speakers, you can.
but if in the HUD menu, or visually you wont see any speakers, I fear not.
Carl
2answers
I have no sound coming from my Hp w1907 monitor
turned off , in the monitor. OSD setup.
cable fell off, (sound) or half plugged in.
sound turned own in PC or muted.
if you can't find out, why, try plugging in the monitor to another system and test it there, bingo, instant answers
My HP w22 Monitor started to make a crackling sound and than all the sudden turned off, or something. It wont come back on. The computer works just not the monitor. Any ideas on how to fix the problem?
Try checking your Cable connections to the Monitor to the Computer and from the Monitor to the wall outlet.The crackling sound maybe normal.Most Monitors make that sound.
How do i turn the volume up
Did you turn up the both (at the PC Audio control panel and at the Monitor control panel) volumes up?
Try using MP3 player or any audio sound sources feeding the monitor audio input to see what happen also.
2helpful
2answers
How do i get the sound to work?
Sound has to be connected to the monitor. Plug the audio cable from the monitor into the green audio jack on the computer at the back. Make sure the sound is configured for stereo and not 7 channel surround. Turn up the volume on the monitor(if there is a control) and turn up the volume on the computer.
How do I turn the monitor volume on for a norcent
Please try to go to Control Panel > select Sound, Speech and Audio Devices > select Sound abd Audio Devices > then at Speaker Set-up select Monitor Stereo speakers. Best regards
My monitor doesn't have sound,but when i turn it off,the sound comes per sec.please help me
when u turn off the system sound comes from motherboard not from monitor if there is showing any speakers in monitor
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
