Possible causes---no water coming in, or water not hot enough from house supply. If the soap tablets look almost dry or new, you are not getting any water into the dishwasher at all. If they are dissolved slightly then check you hot water supply. Minimum temp should be 120 degrees. Also make sure spray arms are turning and not blocked if soap is partially dissolved. No Water is usually caused by a bad inlet valve ( the electric part the house water line connects to).
Is the dishwasher heating ? , check heating element / pcb
