SOURCE: RCA Gemstar Remote codes???
www.remotecodelist.com ..................................................T.
SOURCE: RCA UNIVERSAL GUIDE PLUS GEMSTAR
http://support.rcaaccessories.com/index.html
http://www.remotecentral.com/features/r-rca.htm
Try using the information from these two websites. It may help.
SOURCE: how to program an rca universal guid plus gemstar remote
Hi I bought a JVC 13" tv from Goodwill when I turn it on it's wants a code number. How do I change this?
Thanks
PAt
SOURCE: ive got a rca universal remote without a code search button how do i program it?
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): We could not find an exact match, we think this code will work. 10054 Setup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
SOURCE: programming instructions
HERE ARE THE CODES FOR Philips TV. 1005, 1008, 1014, 1039, 1064, 1079, 1082, 1086, 1099,1104, 1106, 1115, 1116, 1123, 1149, 1150, 1153,1154, 1157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 13511157, 1185, 1186, 1203, 1246, 1295, 1312, 1313, 1351
