Question about Toshiba Tablets & eReaders
How do i fix a encore 2 toshiba with a message that says no bootable device resart system how do i do that
    New Friend:
  • 20 Answers
You should check in your BIOS settings to make sure your internal hard drive is designated as your primary boot device. If it is and the system still does not boot up, you either have a bad hard drive or the ribbon cable has come loose. There is an outside possibility that your MBR (master boot record) has become corrupt and the drive would have to be reimaged.
Posted on Mar 04, 2015
6ya staff
SOURCE:
Says "no bootable device" and its locked up and wont restart
Tablets
I am typing this on a Toshiba Thrive so I am sending you to where I go for answers. In case the link does not work do a search for "Toshiba Forums"
Mar 05, 2016 | Toshiba Encore 2 WT10-A264 Signature...
My screen is frozen
If you just recently did the camera update, it is said (by quite a few) that is can crash the system and you will need to reset it.
*IF* this is the case with you (happened right after camera update), and you want to reset it to correct the recurring problem, consult your owner's manual on how to reset the device or you can see instructions in the online manual here: https://www.manualowl.com/m/Toshiba/WT10-A32M/Manual/424925?page=42
Good luck
Mar 08, 2015 | Toshiba Encore 2 WT10-A32M Signature...
Lenovo IdeadPad Miix 2 says "No bootable device. press any key"
It sounds like the Operating system was not loaded right or the solid state hard drive is bad. Contact Lenovo they will walk you through it and get you back up and running
Mar 17, 2014 | Tablets & eReaders
I need help...
Right. When you try to boot into normal Windows or Safe Mode Windows, you should remover any device from your pc.
Well, here is a guide on how to make a USB flash drive bootable.
http://www.bootdisk.com/pendrive.htm
Jan 15, 2009 | Toshiba Portege 3500 Tablet PC
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
Jan 10, 2009 | Toshiba Portege R100 Tablet PC
Tablets & eReaders Logo
230 people viewed this question
Top Toshiba Tablets & eReaders Experts
Ekse
Alun Cox
David Jercinovic
David Jercinovic
Level 1 Expert
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
