Hi Kaycee.
I suggest you try to reset the power to the TV:
Start off by turning the TV off and unplugging it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
Hopefully this will get it working for you.
If this does not solve the problem, you can go to the online video, "How to Power Cycle a VIZIO TV" - see attached video.
Reference is
https://answers.vizio.com/hc/en-us/articles/200132879-How-to-Power-Cycle-a-VIZIO-TV
Hope this all helps you
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
The Lg lcd was srtruck by a remote and now looks like a small crak on the inside towards the bottom right hand corner and there is no picture but audio does work
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
SOURCE: Fuse location on Vizio 32 in. flat screen.
You need to take the back off the set, the fuse will be near where the power cord goes into the board
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
SOURCE: Vizio shuts itself off
I have found that turning off the power for awhile will work as a temp fix for a couple of days and then just repeat the process.
