Real musicians do change tempo throughout a song, so its not necessarily a bad thing. As long as you like the sound it doesn't matter if you don't stick rigidly to a fixed tempo. Unfortunately you won't be able to fix the tempo after the initial recording so you'll have to live with it or re-record. If you need a click track to record along to, try recording yourself hitting drum stick together along to the already recorded track. As a human you can track small tempo changes much easier than a computer. If you need to create a count in, just copy and paste a section of this click track to the start of the track. I hope this makes sense!
Tascam Digital recording is an effective solution for broadcast-quality home recordings. The Tascam 2488 is a user-friendly tool and useful for home recording situations, especially when writing songs or cutting demos. It even has bus compression and processing for your final mix to give it that "mastered" feel. There are other recorders as well.
Instructions
Learn your gear. The Tascam 2488 DAW offers 24 discrete channels that can be recorded at up to 24-bit resolution. 16 tracks can be recorded simultaneously, via eight XLR balanced inputs and eith 1/4-inch unbalanced inputs. There are several high-quality built-in effects, such as reverb, delay, modulation, compression and a great tool for guitarists: amp and effect modeling. So you can simply plug directly into the console and get live amp tones.
Record or program the rhythm tracks. Most Tascam products offer a large library of built-in drum loops to construct rhythm tracks, so you don't even need live drums just to get a song down. You can designate the tempo of your song from the transport located on the right side of the console; this is where you would use a variety of buttons to make edits, undo or redo and automate punch-ins
Record your base rhythm instrument. Let's say a rhythm guitar. There is a dedicated guitar input located on the front of the console, and once you're plugged in you can use the aforementioned amp modeling features to dial up a sound.
Record the remaining track or tracks. This could include bass, vocals, keyboards, horns or any other instrument. The process is always the same. Arm the track you wish to record on, hold in record and hit play, and the machine begins to record whatever you are playing. When you're done, hit stop. If you want to undo what you recorded, simply hit the undo button.
Repeat these steps on any other instrument you want to record. Plug a microphone into one of the first eight XLR inputs, the first 4 of which have phantom power for studio condenser microphones, arm a track and record.
If you need to punch-in a section, you can automate it by dialing up the time in the song you wish to replace using the auto punch function. When you enable this and choose the time in the song you wish to record over, once you hit record and play it'll start the track a few seconds before where it begins the punch-in and it will only go into record when it reaches the designated time stamp.
Do not rush. Proper recording takes time and patience.
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Try this experiment: Record a click track on track #1. Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks! You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
From your description it sounds like you recorded the midi drum patterns to a track first and then playback from that track is giving you problems. If this is the case it sounds a lot like a bug that existed in the firmware prior to release 1.02 where edits could cause gaps on tracks. You can check your firmware version on bootup and if you don't have version 1.02 installed you can get the firware and instrustion on how to upgrade it here:
