Question about LG Televison & Video
How do I change screen size to read closed captioning?
Picture is too tall to read closed cationing
    Master:
  • LG Master
  • 689 Answers
You should have a button on your remote that says something like: aspect, pix size, screen size...etc
Posted on Mar 12, 2015
Closed caption font size
Size usually is not adjustable.
May 22, 2014 | ViewSonic NX2232w TV
I nannot turn off cations on 73 inch tv
look for a button on the remote most probably labeled " CC " or go into the menu in the audio or setup section and you should find the closed caption settings.
Jul 31, 2010 | Mitsubishi WS-73713 73" Rear Projection...
I can't get rid of the closed cation on my lg tv
take out the eprom ic and the tv will reset.the eprom is a 4 leg ic at the front of the tv board close to the micro if you cant do it your self take it to a tech.good luck.
Feb 28, 2010 | LG Televison & Video
How do i disable closed cation?
go into the menu and turn it off. there are several cc choices one is off.
Dec 28, 2009 | Philips 27PT543S 27" TV
I cannot get close cation on the sylvania 42 plasma TV. I have gone through the menu to set it up but it.But I cannot get close caption to work
Most likely it is in the cable box settings accessed through the cable remote, not the tv settings which are set up through the tv remote.
Jun 04, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Need to get rid of closed caption
If you have original remote for t.v. , hit the button under the sleep timer button on remote, and eventually the closed cation words will be removed from the bottom right corner of t.v. Hope this helps , good luck .....
Jan 07, 2009 | Broksonic CTVG-5463GVC 19" TV
Closed caption will not come on
Should be under language setting it will say somethin like caption 1 or 2
Nov 25, 2008 | Proscan 19LA25Q 19 in. LCD Television
BLack box in the middle of my screen?
iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
Dec 27, 2006 | Sharp 25L-S100 25" TV
Televison & Video Logo
51 people viewed this question
Ekse
RONALD CARTER JR
