The coffee is not grinding
SOURCE: Coffee is not coming out
take out the brewing unit and clean it.
Make sure all parts is on place, try to open the steam knob and make a full cup of water (tea).
Let me know if you need more help
Best regards
/Mirran
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
SOURCE: My SAECO Talea Giro is not working. I have cleaned
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
