Televison & Video Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SK-19H210S has sound no picture
SK-19H210S has sound no picture picture comes on a few seconds after set is turn on
  • Anonymous May 11, 2010
    See solution (possible) in "Can't remove cover to check power supply."-Ken
  • Anonymous Mar 20, 2014
    power is on .the picture apears and disapears
Anonymous
Level 3:
President:
  • Master 1,077 Answers
  • Posted on Jul 09, 2009
Anonymous
Master
Level 3:
President:
Answers
1077
Questions
Helped
774535
Points
4687
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
You have a few choices:
1. If by chance the TV is still under warranty, go that route.
2. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15. 3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
The local cable company has gone digital and now my westinghouse lcd tv sk-19h210s only gets 24 channels. How do I do a channel scan?
Hi, You need a analog and digital tuner in the TV, which it sounds like you don't have, or a digital cable box.
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
2helpful
Westinghouse Model SK-19H210S Won't Turn on just ticks.
Hello, it sounds like you need to replace your power board, you can find price and availability for this power board by emailing [email protected].
16helpful
4answers
Westinghouse SK-19H210S won't turn on.
look for capacitors that have a bulging top instead off being flat probably the 2200uf 10v cap
HDMI port not working
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
No video, has sound
Does the sound come on when it first turns on? If so, the high voltage transformer is probably bad. Most problems with powr in these sets are due to design flaws in the switch mode power supplies. It seems the bias voltage in the secondary side of the optoisolater is incorrect, causing overcurrent protection. They are not easily repaired and not cheap. Check the 2200uF capacitor for leaking current--replace.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
