Maytag Bravos MTW6600T Top Load Washer Logo
k
kelly golden Posted on Mar 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer spins to well, can't get the wrinkles to come out even on the delicate cycle.
L Heme
Level 3:
Master:
  • Master 395 Answers
  • Posted on Mar 06, 2015
L Heme
Master
Level 3:
Master:
Answers
395
Questions
0
Helped
57463
Points
1163
Check the heat sensitivity or shorten the cycle.
  • kelly golden
    kelly golden Mar 06, 2015
    have tried every cycle and cloths level. Repair man came out and said he never heard of such a thing...
All my dark clothes have soap deposits on them and clothes seem exceptionally wrinkled when I take them out of the washer.
If load is wrinkled the load may have set in the washer to long it is recommended to remove wash as soon as it stops or the load was too large for the washer capacity. Loads must be balanced and move freely during washing. Also using too much detergent could cause the deposits on clothing. Using an he ( high Efficiency) detergent might help. Using delicate or another cycle with low spin speed will reduce wrinkling.hope this helps
My washer recently hasn't drained all of the water during the spin cycle.
how is the spin in the delicate cycle compared to the reg cycle?
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
1helpful
Water is in the drum after a complete washing cycle, you can't see the water but you can here it slushing around and leaves a foul order when not used for several days.
Make sure that the outlet hose is not blocked and the filter is clear.
If this is OK then the following from Maytag may be helpful. If not call a repair man for service.
Is the Delicate or Hand Wash cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such as the Delicate or Hand Wash cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to protect the delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was Max Extract selected?
Ideal for heavy loads such as towels and bedding, Max Extract removes more water from loads during spin.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select Drain/Spin or Spin Only cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form or hose retainer on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manuals and Literature search below.
Is your outlet voltage low?
Check the electrical source or call an electrician.
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
1helpful
Draining or spinning will not work
i think you have something stuck in the pump.a sock or something have some one check it for you.im pretty sure youll find something in the pump though
1helpful
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
See also: Why HE High Efficiency detergent is required.
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Check electrical source or call an electrician.
Will not spin,
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Washer won't move into spin phase on the Regular Cycle setting.
Have you checked the lid switch??? This will prevent it from spinning look on the lid you will see a plunger.. watch where it goes down to you can use a pen to press the sw while the lid is up to see if it is working ...PS: dont forget to set it into the spin cycle first..let me know what happens
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
