Hi. If you can hear the wiper motor operating but the wipers aren't moving you will need to follow the linkage. often the splines where the wiper arms fasten to the wiper mechanism can come loose or strip the internal splines. you would need to test the tightness of the fixing nuts at the base of the wiper arms, they should be fairly tight. there is a similar set up between the wiper motor and wiper mechanism that again could be loose or stripped. I would advise ensuring the ignition is off or battery disconnected before you test these nuts as if they operate whilst your fingers are in there it will hurt like hell and probably make a mess.
