NO NEED TO REMOVE WHOLE DASHBOARD!!!
REMOVE TWO7MM SCREWS FROM THE BOTTOM OF STEERING PANEL & PRY AND REMOVE PANEL.
NEXT REMOVE TWO 7MM SCREWS ON BLACK PLASTIC STRIP THAT YOU SEE AFTER
REMOVING STEERING PANEL....PRY THIS STRIP OF PLASTIC OUT JUST A LITTLE
AND CUT IN THE MIDDLE .
NEXT REMOVE TWO 7MM SCREWS FROM AROUND TOP OF
INSTRUMENT PANEL
(BY GAUGES ) PRY PANEL STARTING FROM AROUND VENT ON LEFT BY DRIVERS
DOOR ""THIS PANEL WILL STAY IN PLACE LOOSE... NO NEED TO REMOVE!""
NEXT YOU WILL SEE 0NE 7MM SCREW BY GEAR SELECTOR AREA.. BEHIND THE LOOSE
PANEL REMOVE THIS SCREW.. ALSO IN SAME AREA BUT LOWER THERE IS ONE 7MM
SCREW THAT NEEDS TO BE REMOVED THAT HOLDS LOWER DASH PAD ITS FOUND
BEHIND LOWER CORNER OF DASH PAD.( LOWER DASH PAD GAS PEDAL AREA )
"DON'T"!!! REMOVE THE FOUR 10MM BOLTS!!!! IN SAME AREA
NEXT REMOVE
RADIO
/AC CONTROL TRIM WITH THIN SCREW DRIVER OR PANEL TOOL IT HELD IN BY SIX
CLIPS...NO NEED TO DISCONNET ANYTHING IT WILL STAY THERE HANGING!!
NEXT REMOVE TWO
CENTER CONSOLE
LOWER LARGE PLASTIC CLIPS BY FLOOR MATS. NEXT UNDER SQUARE BLACK RUBBER
AT CENTER CONSOLE REMOVE ONE SILVER SCREW. MOVE SEATS FOWARD AND REMOVE
TWO 8MM SCREWS FROM SIDES OF CENTER CONSOLE FROM BACK SEAT.
PRY CUP PANEL SECTION THAT WAS HELD DOWN BY SILVER SCREW ...PRY UP TOP HALF OF
CONSOLE STARTING FROM SECTION WHERE ARMREST DOOR IS.. DISCONNECT LIGHTER PLUG AND REMOVE PANEL .
NOW YOU WILL SEE SIX SCREWS STARTING FROM BELOW RADIO TRIM WORKING BACK TO ARMREST DOOR
