SOURCE: Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
SOURCE: whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
SOURCE: Whirlpool Cabrio Dryer Wont go past sensing light
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
