The carb is factory set you need to remove carb you will then see two screws one marked L and the other H with a small hacksaw cut a slot across both screws don't worry about cutting into carb body this can't be helped screw both screws fully in then back them off 1 and 1/4 turns this rough sets high and low running start saw set low speed first adjust screw in or out to get best low running then rev saw to max.and adjust max revs do the same as you did with the low speed screw to obtain max revs this should solve your problem.
