That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
Check the output of the charger to make sure its actually working, if it is most likely the battery connector inside the unit is bad, or the battery is bad.
get ur battery out frm ur mobile fr 10 secs then connect charger then aftr upto 10 sec aftr that put battery back and switch on. if that doesnt work make sure the voltage of ur charger is compatible with ur phone . if still doesnt wrk maybe problm with ur port note: sometimes the charger knob gets lose try putting it correctly good day :)
Can the tablet turn when plug in to ac adapter/ home wall charger?
Maybe I can help you if you can tell me the model of your tablet.
EZBUY batteries and chargers laptop batteries
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
It could be the charger. If you have anything else that it would work on then you should try it. If its not the charger it may be the charger port and as far as I know you will have to have it send it the company or find a repair shop and have them replace it. You could possibly take the charger to radio shack or a store like it and ask them if they could try the charger on another tablet, they may do it.
The exclamation mark means that your tablet has no battery left. You should try plugging your tablet in for a few hours before turning it on (if it doesn't turn on by itself.) If that doesn't work and you still see the exclamation mark, I suggest that you ensure the charger is properly plugged in to the socket and that its properly attached to the tablet.
