Not spinning properly
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
