Question about Sony Bravia KDL-40S4100 40 in. LCD TV
Will My Sony tv Bravia 42 inch power cable work with a Sony Bravia tv 32 inch as onec has a 2 prong female connecter and the other has a 3 prong female connecter
    Top Expert:
  • Sony Master
  • 76,204 Answers
Yes. You can. Even though the number of prongs are different, there will be only 2 conductors connects the TV circuit.
Posted on Mar 08, 2015
  • 1 more comment
  • The Wyzzyrd Oct 15, 2015
    It should be mentioned that using a two prong cord on a three prong TV could cause a risk of electrical shock.
    The third prong is earth ground.
    It could also damage external devices (DVD,game console) and the TV.
6ya staff
SOURCE:
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have a KLV-32U100M and recently I've noticed a wide bar of color rolling up the screen and a I hear a slight hum from the speakers. This occurs when different devices (cable box, dvd player, Wii) are on...
You may have an earth ground problem with your house electrical wiring-- third prong in AC socket. Get a 3-prong to 2-prong plug adapter ( also called an "AC-cheater plug") and put on TV cord. Try again.
May 01, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Power Cable Replacement
Try ebay. If unsuccessful you may have to convert the plug on your set to a standard one that will work with a normal standard wire.
Jul 28, 2017 | iLO V27DMBX Television
Sony BRAVIA 32 inch
I had the same problem with a old Sony TV.
To find out if the problem is temporary
  1. Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
2. Unplug the television power cord from the electrical outlet.
3. Let the television remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
5. Turn on the television.
If the light is still flashing the tv has stop working and you will need to buy a new one.
Dec 08, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Sony Bravia KDL-40S4100 40 in. LCD TV Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
