Cameras Logo
Christine Marie Posted on Mar 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak easyshare Z5010
Wont turn on, changed batteries took out cards cleaned it still nothing
Harrie
Level 3:
Top Expert:
  • Kodak Master 6,746 Answers
  • Posted on Mar 08, 2015
 Harrie
Kodak Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1284130
Points
83153
Perhaps you just need a new battery. or the camera is defect.
Measure the voltage on the battery with a multi meter. It should give a little more that what is printed on the battery. so when it says 3,7 V on the battery you should measure 3,8 or 3,9. If not, even 3,7 outside the camera is not enough, then you need another battery.
My easyshare z5010 when I touch the zoom, shuts off the camera
Make sure your batteries are good. This sometimes happens when the battery is low.
File format
Try formatting the SD card with camera. Please take a backup of the SD card to your computer before you format.
Kodak Easyshare Z5010 takes black pictures only when in manual mode. I reset the settings but it still takes black pictures.
Check the settings that influence the exposure when your camera is in manual mode. There are three variables that you can adjust to change the exposure: ISO sensitivity, aperture (diaphragm) and shuttertime. When for instance the ISO is set to 100, aperture to F16 and shutterspeed to 1/1000 you will need a huge amount of light to get anything else than black pictures.
In a normal daylight situation you should get some results when using approximately the following settings: ISO100, F5.6 and 1/60 shutterspeed. Adjust these settings depending the light conditions and the results you get.
My kodak easyshare z5010 has a lock i cant look at the pictures
Do you mean the lock on the memory card , take it out of the camera and youll see a tiny plastic switch , move it to unlock and that should do the trick , best of luck
13helpful
2answers
My C180 easy share won't turn on.
Kodak's advice is disinformation & damage control: this is actually a product defect--it's a firmware bug that affects most Kodak Easyshare cameras, but Kodak will probably never admit it. The problem usually starts after you change the batteries or connect the camera to the computer. Google for "Kodak easyshare wont turn on" - there are more than 8,000,000 results. Just returned my new camera to the store because it locks up every time I change the card or transfer pictures via the USB port. Thought I was getting a good deal, but now I know why this was the cheapest camera they sold. What a waste of my time & money. So it's usually NOT the batteries fault--the real problem here is Kodak's low quality engineering.
My kodak easyshare DX4330 wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera. '
Note KODAK no longer repairs this model. Instead they offer a Trade up option where they offer to trade the model for a newwer model 25-20% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
1helpful
2answers
I took the batteries out of my Kodak C513 while it was turned on so I could clean the lens, and when I put the batteries back in, I could not turn it back on.
Here are the steps:
Contact KODAK:
Why does the camera not turn on? i only used it 3x, changed batteries 4 x and still wont turn on is only 2 months old
Here are the steps:
Contact KODAK:
Doesnt start, but it flashed black vertical lines.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
