Refrigerators Logo
A
Anonymous Posted on Mar 10, 2015
Refrigerator not cooling; Freezer not freezing.
Jorgie the appliance guy
Level 3:
Top Expert:
  • Refrigerators Master 5,639 Answers
  • Posted on Mar 12, 2015
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1521770
Points
32630
First do u hear the compressor running? any clicking sounds? cold control may be bad? stuck in defrost mode? do u hear the fan running? u can manually take it off defrost mode by placing a small philips screw driver into the tiny hole underneath it the ( cold control thermostat), and turn it slowly till u hear one click this will take it off the defrost mode. if ur problem is the cold control. if that does not work u may have a bad compressor relay and can do a 3 in 1 hardstart and it should kick back in and work agin
My amana refrigerator is not cooling, freezer is working
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Freeze run cool but want freeze water on the floor under the upright freeze
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
My frost free freezer stops freezing although it stays cold and then I have to switch it off for more than a day before it starts freezing again
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Refrigerator cooling fan freez so not cooling.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
gf
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
