I have a RCA tablet model# RCT6272W23 the screen was broken. I replaced the screen with one that my friend had. Everything but the brand was the same . I mean everything perfect to the point. It turns on and works . But the picture size is off. And the screen calibration is off a little bit . How can I fix this or is it possible to be fixed
Greetings.
Not all screens are interchangeable even same Make and Models can have problems. What is the make of the screen tablet you used to replace on your broken one? It may have some issues with size or your tablet may have been damage when you cracked the orginal screen.
Try if you dare flipping it 180 degrees around to see if it fixes the issue.
Good luck
chadman
SOURCE: how to calibrate my tablet
You need to keep doing it till calibrated, happened to me but got it after a while.
SOURCE: I have a RCA tablet rct6272w23 and I can't connect
Hi
To connect to the Internet with a tablet, you need to have either a SIM card with mobile access (3g or 4g) or a Wifi card in the tablet and access to a Wifi Hotspot. I downloaded the manual for your tablet here:
http://www.rcatablets.com/sites/default/files/CT9272W23%20IB%20English.pdf
and looking through it the first option does not exist for you as there is no facility for a SIM card.
Therefore you need to access a Wifi hotspot - somewhere. It could be your home router, a cafe, a railway station or a multitude of places. In order to access the Internet this way you must follow this procedure:
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it, and enter a password if necessary.
4. Alternatively, if your Wi-Fi router supports Wi-Fi Protected Setup, tap the WPS icon at the top of the screen, and then press the WPS button on your router.
5. If your network does not broadcast its SSID, tap the Plus icon + at the top of the screen, and enter the Network SSID (name) of the network. If necessary, enter security or other network confi guration details.
In public places you may need to pay to get the necessary access password.
Hope this clears things up for you
SOURCE: I turn on zeki tablet and it possible up that
From off, press power on and volume+ together until reset page comes on, then move with volume and select with power!
SOURCE: rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
well i asked my friend what brand it was and he told me it didnt matter. he said the only thing that matters is the chip in it. so all i got is that it is a rockchip on my bord 'im not sure what chip is in the other tablet. but one thing is that the picture does look like it is zoomed in a little bit.
