When i put my batteries on charge the red light flashes foe a couple of mins then flashes fast and stops charging
SOURCE: Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
SOURCE: i have a dewalt dc011 radio, it will not charge a
Sorry to say the unit has a short in it, You need to have it serviced to fix the problem.
Testimonial: "thanks, just had it looked at it's the charging unit thats gone £80 to fix :-( "
SOURCE: I have a problem with a battery and charger. It is
Take your battery to a Batteries Plus store and have them test it. I suspect you're going to need a new battery. That one is no longer taking a charge.
SOURCE: 12v drill/driver not holding charge
Seems like your batteries need to be repaired and recharge! For this, let me suggest you the ultimate Nicad battery repair guide. This is very efficient and works on all weak or dead nicad batteries. With this nicad battery fix manual, you can repair, recharge and make your old batteries work like new ones. it is easy to understand and easy to work on. Recharges the batteries within no time. Try it, it is really helpful!
