I dropped my phone nearly everyday [no cracks] and its 5 years old. i dropped my iphone into cold tea about 2-3 weeks ago. would any of this be the cause?
Water will have an affect on it if it has not been dried out properly the screen controller chip that is on the logic board will get damaged, =, they are not waterproof, you will need another logic board to repair this fault., can also damage the battery and the screen being in water for any amount of time.
SOURCE: my iphone 1.1.3 doesn't work
press power button and home button together. press them 2gether for 10 secs. this is soft reboot.
this shud reboot the iphone.
u may need to put ur network settings again.
chao.
SOURCE: IPhone - Can't hear incoming calls. Does not ring or Vibrate.
I had a similar problem....it was usually after I unplugged the headphones....the phone thought they were still attached, therefore, nothing came over the speaker......try plugging in the headphones, then unplugging...that worked for me.
SOURCE: my iphone 3g screen just went black but i can hear the calls when it rings..
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I dropped my iPhone as a result my phone rings but
seems like broken lcd hatch
replace it
buy a replacement screen
good luck man
SOURCE: Dropped my iphone 3G, screen went black with some
It just happened to my this afternoon. My iphone dropped out of my pants pocket to the ground. The front lcd of the iphone hit the ground and it when blank/black. My iphone happened just like what you've described. I got my fixed. I opened it up and found the connector of the lcd was loose. I securely reconnected it and voila!!!! It works again like a charm! Goodluck to you all who has the same problem.
