Turn it upside down to get the model / serial numbers. These may be found on the box as well. Now, not knowing if you registered this printer with the manufacturer or not, I would still call them for Tech support. Hewlett Packard are real good people to talk to. Their website is helpful too. Google / Bing it, and go to their "Official" website. This is the Best thing that you can do.
If it's still new, take it, in the box with receipt back to the store where you bought it...But MAKE SURE: All the numbers match! I have had printers in the past that were packaged wrong, and the store would reject it, and not touch it at all. This is why the website is best; HP will even send you parts or a replacement free of charge in order to keep a happy customer.
it sounds like the printer has not accepted the changed cartridge.
Try turning the printer off at the mains for 30 seconds then back on again, it sometimes works, or if that fails take out the cartridge's turn off printer for 30 mins then back on re insert inks and see if that works.
If it fails then there could well be a chip set failure on the cartridge you have replaced or maybe another cartridge within the set.
It's well worth saving the cartridge too as compatibles sometimes fail to be read by your printer but rarely the actual cartridges fail, you can put that same cartridge back in later for it to be accepted by the printer.
Change Ink Cartridge in Epson Printer isn't a difficult. Just follow the simple steps to change ink cartridge in Epson Printer:
Ā·Turn on Epson printerĀ·Open its cover or scanner then left the unit of the scanner and wait for it.
Ā·Ensure that the print head is at replacement position. If not the press "Maintenance" button.
Turn the printer on. Lift the lid that covers the print-head mechanism. In a few seconds, the print-heads will slide to a position where the ink-cartridge can be removed. Then, "unlock" the ink-cartridge from its socket, and gently remove it. Replace it. Then, "lock" the ink-cartridge into place, and close the lid. Print a test-page.
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
Turn on the printer.
Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
Your printer will need either a new printhead, or possibly a purge assembly that cleans the printhead. Best to have a shop check it out so
you don't buy a part you don't need. If it can't clean then even a new printhead won't help.
Press the power button to turn off the printer. Hold down the transfer and left arrow button at the same time. While holding them down at the same time turn on the power button. Let it go through the initialization process and once completed, the head should be in the up position. Open the cartridge door and push the cartridge to make sure it is latched and locked in place. Once the cartridge is latched, release the latch and the cartridge should release itself. Remove the cartridge from the printer.
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
