Question about Apple Ipad2 32GB Wifi
What is wrong with audio. One day it works, next day it dosen't
    Sergeant:
  • 215 Answers
You are just cliking without notice on the mute button or slide
Posted on Mar 11, 2015
6ya staff
SOURCE:
MY KINDLE FIRE FROM AMAZON IS NOT WORKING. IT WAS CHARGED, AND WORKED FOR 2 DAYS AND THEN WENT DEAD. I WAS TOLD IT NEEDED TO BE FIXED BY AMAZON. WHAT SHOULD I DO?
I would say that the store informed you that it was a warranty job and that amazon would have to be involved
call amazon direct and discuss a warranty exchange item with them or where a service agent is that you can take it to
Mar 24, 2016 | Amazon Kindle Fire HD
Let me try again: what is wrong with the audio one day it works next day it dosen't
Hi, First make sure that your sound is turned on. Look in menu and properties and see if the speaker doesn't have an X on it. Then try you audio again. Good luck.
Mar 10, 2015 | Apple Ipad2 32GB Wifi
Can I connect my hmdx rave to my next book?
Yes, you'll need a 3.5 mm audio cable (PC audio) with M/M ends. Connect the cable between the headphone jack of the Next Book and the Aux Input of the Rave speaker. The Aux Input jack on the speaker is between the charging port and the On/Off switch. The headphone jack is between the power button and the DC Power Input port on some Next Book models; you should check your unit's documentation for the exact location. Only the volume controls on the Rave speaker will work. You'll need to select tracks and press Play/Pause on the Next Book.
I hope this helps.
Sep 29, 2014 | Tablets & eReaders
NEXT BOOK WILL NOT CHARGE
there are most likely two things that are wrong with your tablet, 1. your battery is worn out or your charger/chargers might be worn out.Try plugging your tablets charger back in while its off and then turn it on. If that doesnt work then try the pinhole reset button while the charger is plugged in. Since your charger might be faulty have a professional check for shorts in the charger. if none of these work consider replacing the battery, the charger, or the tablet itsself. if this doesnt help you i apologize for wasting your time with answers that are incorrect or answers that you may have tried before.
Jul 04, 2014 | Nextbook Premium 8 Se Android
Cannot hear radio broadcast audio
First thing to check is your settings for sound. Go into settings and click on sound . The options are there. Make sure it's not on mute or something similar. Try changing the setting. Next is plug in your earphones in the jack. If that works then your jack is open after you take the jack out. If none of this works then a connection to your internal speaker has come loose or off.
I am not familiar with your unit. Just standard stuff on all tablets is what I am suggesting.
Apr 14, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Worked one day and froze up and cut off the next day
You may have to reset it. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 13, 2014 | RCA Tablets & eReaders
Volume not working
You have lost your audio driver. Go to manufacturers web site, help and support center, and download the new driver. That should fix your problem
Nov 15, 2009 | Gateway M280E
Hi, my mom just got a IBM thinkpad. It worked just fine then the other day she told me the keyboard and mouse didn't work.I know somewhat about computers and tryed to fix this problem.I plugged in a mouse...
Check if you have any button on panel says about to lock the keys and mouse? Use your manual book if you have one. Lenovo has got this buttons that locks the keys and mouse to prevent unautorized use while you are away. Possible located next to the audio or power button.
jmc
Aug 18, 2009 | IBM THINKPAD X200 TABLET SL9400 2GB 160GB...
Toshiba Satellite 1905
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves!
Good luck
Mar 17, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Apple Ipad2 32GB Wifi Logo
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
