Expert
- Posted on Mar 11, 2015
Re: restore sound on my Tv, suddenly lost.
- Check if the mute button on the cable box/TV/VCR is activated. If so, turn off the mute feature
- Verify the volume on the cable box/TV/VCR is not turned all the way down, either by adjusting the volume level on the equipment itself or with the remote control
- Check if the TV has an earphone or headphone jack. If so, make sure there are no earphones or headphones plugged into it
- Check if the Cable Box/TV/VCR has a SAP/MTS switch (Secondary Audio Program / Multichannel Television Sound). If so, make sure it is set to the proper setting. Consult your TV/VCR manufacturer's user manual for information for your specific TV/VCR. Click here for information on changing this setting on a Cable Box
- Check behind ALL TV and equipment (Cable box, TV, VCR, DVD, stereo receivers, etc) and the coax cable at the wall outlet for any loose or damaged connectors
- Make sure all equipment and connections are hooked up correctly for the video and audio based on the type of connections being utilized
