Showing fault f51. what is f51
The F51 fault code on your Cabrio washer indicates that the control board is not sensing the proper drive motor spin. To clear the fault code, press the Pause/Cancel button.
Make sure that the drain hose is not stuck way down the stand pipe. This can cause siphoning of fill water which will inhibit proper motor rotation.
Check to see if the wash basket spins freely. If it does not, you may have an item of clothing stuck between the outer tub and the inner basket. This restriction in rotation will also cause an F51 fault code.
If these tips do not help you resolve the F51 problem, then you probably have a component failure. Possible failures include: wire harness or wire connection problem between the machine control and the RPS sensor (Rotor Position Sensor), a failed RPS sensor, a failed drive motor, and a failed machine control board.
F51
Heater pressure switch
The program is interrupted and the drain pump is operated. The display
shows Technical fault F51. Call Service Department. The buzzer is
activated for 2 minutes.
Background information:
Start position:
One second after the program start, heater relay K1/1 is activated. This
enables a check as to whether the contacts on heater pressure switch B1/13
have closed on switching steps 21/22 or 11/12.
Cause:
Heater relay defective; contact open.
Remedy:
Replace the heater relay.
Cause:
Heater relay solenoid defective.
Remedy:
Cause:
Connection from heater relay to electronic module open-circuited.
Remedy:
1. Check plug connections.
2. Check the connection wires for continuity.
Cause:
Heater pressure switch open- or short-circuited.
Remedy:
Replace the heater pressure switch.
Cause:
Connection from heater pressure switch to electronic open-circuited.
Remedy:
Cause:
Foreign objects in heater pressure switch.
Remedy:
if you have any further questions message me back and please remember to rank this opinion it allows me to help people in similar situations in the future Thanks again Rick
