One of the best ways to prevent Printer error code "3501" from happening is to install latest version of firmware. To update firmware manually you can place the calibration sheet over the scanner and press START button. You can then click the HELP icon and select Maintenance option. From there, select Firmware Upgrade option and follow the instructions given there to download the latest firmware version; free of cost.
http://www.fixya.com/support/t1000639-whats_error_code_3501
Error 3501 is for the front access door open and you will get that msg number of times you open the front access door and dont worry about that error......if the printer is printing dull colours then try and clean the print head from the menu or from the home center clicking on the question mark in the top right and click on maintenance and then click on clean print head.....if you still have the same issue it could be a refilled ink or non kodak ink that you are using....if the ink is genuine kodak ink then contact kodak tech support as print head needs replacement.....let me know if this was helpful
