SOURCE: optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
SOURCE: Service Printhead Error
this problem come whene printer fuser chamber have faulty ,
fist of all do service of fuser and check
after than change pressure roler and teflone slive if problem not solve
SOURCE: 935 Service Printhead Error
This error indicates that the Printhead ( Laser Scanner ) is defective. Sometimes turning the printer off for a little & then turning it back on, gets rid of the error but it will usually return. The printhead is situated at the top of the printer under the top cover. It will need to be replaced.
SOURCE: 935 service printhead error
Hello. Unfortunately, if that's the case, there's not much you can do about it but have it serviced. Hope I can assist you more with it.
This means that the printhead is defective. The printhead is the actual laser scanner unit which is under the top cover. It will need to be replaced.
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
