My unit closed immediately upon opening since like 1 day after the warranty ran out. It bothered me. I finally tore it apart and this fixed it.
Take the cover off. As you are facing the front of the player, the blue sensor switch that controls the tray will be on your left in the middle of the carousel. Push button to open tray and locate it as the tray opens. Grab the tray and also the carousel and hold them so you can see the little blue switch. Use a tiny screwdriver or toothpick or other slender device to "flick" the switch fully forward and backward several times. Let go of the tray and try the button. If it still closes immediately, repeat the flicking. Try it again.
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
i would check if your eject button is stuck if it is try to pull it out a little with small plyers or its the eject sensor or finally it might also have something in the way of the tray if you dropped it on accident or something it will keep opening if something is in the way. hope this helps.
i had exactly the same problem on a LG-RH278H resp. a Medion MD 81733. I solved it by opening the micoswitches, cleaning the contacts and streching the springs inside the switches a little. The Problem was, that one of the microswitches stayed conductive even when it was off/open.
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
i know this sounds carzy but mine just did that and i pushed it in hard but not too hard and then tried opened it and when i hit the close button it worked
