Re: My kyocera fs-1370dn suddenly says it is missing a...
The developing unit is where the toner sits upon.Remove the toner cartridge and ensure that the developer unit is correctly inserted.Then re-instal the toner cartridge.
The FK-150 fuser is the correct fuser for the FS-1028MFP, FS-1128MFP, FS1350DN, among others. The FK-170U fits the following Kyocera printers: FS-1035 Mfp, FS-1135 Mfp, FS-1370DN and FS-1120D. There are a few other printers. The design changes means they can't be substituted.
the drum unit is full of waste toner empty it by removing drum unit and removing small covers on both sides dump all toner out of unit then reinstall the covers then the drum unit
you will need to check that the developing unit connector is in proper conection with the printer.
Also check that there is no dust or toner resedue on the connector.
Empty the waste toner from the back side of the drum unit. Then remove and reinsert the waste toner sensor connector from the controller assy (main pwb).
Generally this printer can be separate into 4 major part: Printer body,
Toner container, Developer unit and Drum unit. The developer unit is
the unit where the toner container "mount" on it and it should be
removed to allow cleaning task every time the toner container is
replaced. U may get this error message if the developer unit is
not install properly after u replace a new toner container. Just lift
the developer unit together with the toner container out of the printer
and then insert back properly into the machine.
