I've seen this issue many times on this series of Vizio sets, you have a bad EEPROM IC on the main board, either change the main or order and solder in a new IC if you have advanced soldering skills, needless to say the chip will be a fraction the cost of the board.
do a factory reset by pressing power+ top volume+ home button together on the boot screen (the screen that says your phones name) and use the volume key to go up or down and home to select, go down and press clear chachie and data (separately) and press reeboot phone (note: once a photo of an android or picture comes let go of the home button when getting the factory reset screen)
this screen should pop up and press reset (note all your stuff will be gone and the phone will be like how you first brought it in an shop)
Hello, go into your BIOS, make sure the hard drive is selected to boot from. Then, look for a setting for factory reset, make sure it is also enabled. Then shut the computer off for 2 minutes. Now hold the zero button down and press Start, windows should load and then you should see the factory restore/reset window warning you that all data will be lost. Click YES, select Recovery of Factory Default, then follow the prompts to get windows installed. Hope this helps.
Second solution:
Restart windows if the Factory reset does not work. Before you see the BIOS or windows logo, press several times on F8 till you see a black screen with a few lines of information. Click Last Known Good Config and then Enter.
Last Solution:
Restart Windows, press F8 several times before you see any writing or logos, once you see the black screen with a few white lines of information, press Repair my windows. If you get the windows could not fix this problem, select try another method, it should take you to another screen, select US, then user name, put in password if you have one, then select Restore.
If you peer into the screen can you make out anything on it like as if the back lighting is bad? Also it may be set to night mode as well. You can try a factory reset. I have seen their screens go bad from time to time. If none of the above work. Send it in to Raymarine.
