Canon 2 Original Printer Inks For Pixma Mp140 Logo
Y
Ysmael Joya Posted on Mar 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why canon pixma p200 only can copy ltr why it cannot proceed to a4
CheckitRight
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Canon Master 1,363 Answers
  • Posted on Mar 12, 2015
CheckitRight
Canon Master
Level 3:
Renaissance:
Answers
1363
Questions
Helped
646600
Points
2795
A$ is not a U.S. size. you should although be able to override it in the menu mode, but it will be smaller and may cut off text or image.
1helpful
Ir 2420 canon printer displays load correct paper LTR plain
check sliding plastic paper size device in bottom of paper tray is not on LTR if it is meant to be A4
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
I need to set my Cannon IR 6570's Tray 1 & 2 into A4 it is in LTR please tell me the solution to change it to A4
code for changing LTR to A4
*28*
copier
option
then goto CST
change reading from 18 to 6 in both
it done
1helpful
Half picture when making copy in A4
A4 is not a US size if you choose A4 the paper must be that size--
US uses Ltr-- Lgl and 11X14.
4helpful
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Trying to receive a fax. Display says
You have to cancel the fax. If its saying that then the paper sent to you was a legal sixe 8.5x14 and needs that type paper to receive the fax. Some faxes have legal trays and A4 but most don't.
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Copying
Maybe you pushed the small button on the left "two sided"...I did and got the same reading...I pushed it again to return. I think that is what happened...
old marine
old marine
ZJ Limited
ZJ Limited
