My Windows 7 stops loading and gives me error 1627
SOURCE: What to do? HP Deskjet F380 Error with Cartridge 21b.
hi!!!
removed the cartridge
and placed it back properly!!!
SOURCE: Have Windows 7 on my laptop. Have a HP Deskjet
simply download the new drivers from HP and install them , that will fix your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: HP 6940 Deskjet driver not installing WINDOWS 7
hi,the reason why it most probaly comes with that error is that the driver is not meant for windows 7,so go on line check hp site, printer drivers and download.
SOURCE: Download file now RFU LOAD ERROR
Upgrading Printer Firmware
WILL SOLVE YOUR ISSUE
HP Jetdirect firmware images have an extension of *.dld while the printer
firmware images have an .rfu extension.Once imported into the repository, the files physically exist under the following location on the HP Web Jetadmin server:
C:\Documents and Settings\NetworkService\Local Settings\ApplicationData\Hewlett-Packard\HP Web Jetadmin\WjaService\config\FirmwareUpgrade
check the document from the hp
SOURCE: Will HP Deskjet 722c work with Windows 7? There
If you are using a 32
bit version of Windows 7 you can add a driver using the following: go
to the Devices and Printers folder, Add a printer, Local printer,
LPT1: (or which ever parallel port the printer is connected to),
select the Deskjet 720c driver. You may need to click on the Windows
Update button if the driver does not show up initially in the list.
If you are using a 64 bit version of Windows 7 there is not a solution at this point, the supplied drivers have an issue.
I have Windows-7 (64bit) in my Toshiba laptop. After trying to load a Brand New HP Deskjet Printer-2542 with its CD (and I also tried with the HP Wizard directly from the HP site) it loads it but stops at step-2 and gives me this error-1627 message>>>Error 1627 for package C:\program files\hp\hp deskjet 2540 series\driver store\yeti\hpvy11.inf.............I tried several ways and read/google others who had this problem but I didn't succeed in fully loading its program. What's next to do? (Pls note that my OLD VISTA Acer laptop did succeed in loading 1-2-3 and it works/scans/prints with that old laptop) But with Windows-7 it won't give me Step-3 to which it would give me the commands to print/scan/etc....it stop at 2 and gives me that error message 1627 all the time ...thanks, hope you give me step by step instructions on-what-to-do. I am sure it is a Windows-7 issue.
