SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
SOURCE: i have 2 lorex dvr's. both need web access, can it be done
there are a few ways to accomplish this. one way is you will need more then one static ip. one static ip for each machine, you will then be hitting them on the same port but different ip's. the simplest way is to change the web port setting in the lorex dvr from 80 to something else in the second machine.
SOURCE: i unplugged my L23WD system while trying to expand
U over loaded the system right there,4 to 8 tries 4 again might work again,if have u not burn out the expanded ports already.
SOURCE: Reset & Software for Netrome Tetragon 4-Channel DVR
Way to go , Jeremy!
Thanks for updating !
