Tablets & eReaders Logo
K
Kaye Simpson Posted on Mar 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I open downloaded files?
Downloaded simple games (.exe) but when try to use get message 'can't open file'. Pendo website help page downloaded manual in PDF but get same can't open message. What am I not doing right?
Glenn
Level 2:
Sergeant:
  • Expert 139 Answers
  • Posted on Mar 13, 2015
 Glenn
Expert
Level 2:
Sergeant:
Answers
139
Questions
0
Helped
36324
Points
537
I'm not sure what tablet and operating system you have but .exe files are typically Windows-based applications. Those won't run on a Android or Apple tablet, for example.
For viewing PDFs you need PDF viewing software. Again, depending on the tablet version you have you may need to install the appropriate version reader. PDF is an Adobe product and available from them for free. Adobe Reader Download Free PDF viewer for Windows Mac OS Android
2answers
I want to transfer my music from my ipad to my android tablet. I downloaded droid transfer setup exe. When i try to use it it tells me that i don't have an app that will open it.
Hook up a USB cable from your ipad to your computer. Download the music files and then connect the android phone the same way and put the music files into the music folder on the droid.
1helpful
Have downloaded e-books from the library, but can't delete them from my Nook.
For some books, downloaded from your PC, the only way to delete them is to attach the Nook Simple Touch to your PC and open the Nook Simple Touch on the PC. (For a PC, open the computer icon and look for the Nook icon and click on that.) From your PC you can delete files from the Nook Simple Touch or move them off the Nook Simple Touch to your PC.
IF you have a MAC or if my advice doesn't work, you should contact the Nook support. It is at the Nook website. Click on Nook and look for Nook support.
Downloaded files on galaxy tablet 10.1 does not open, help?
you dont mention what types of files you downloaded but, I'll try some basics. if your security settings require downloads to be from google play or the samsung app store, you have to reconfigure your settings. Also, the downloads must be android compatible. if they need flash, you will need a browser with flash built in like puffin as flash stand alones are useless. finally, you deleted files to make room? you might need to be certain you didn't delete any essential files or files attached to factory installed programs. without knowing what downloads you are trying or where they were downloaded from. I can offer nothing further. good luck
2answers
I downloaded an app---now how do I install it.
Go to your App Store and see if it there? If it is try open or install. If it is not there you will need to reinstall.
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Safri can't download ipayit server
Exe files cannot be downloaded to iPad.Only apps from App Store be installed.You can search store for similar app to do what you require.
12helpful
5answers
How can I download .exe files onto my iPad Safari keeps saying it cannot download file
.exe files are Microsoft Windows Executable files, that can only run on Microsoft Windows. They cannot be run on the iPad, so Safari doesn't download them.
The place to get apps for the iPad is the App Store - have a search, there'll probably be something that can do what you need. Out of interest, what are you trying to do? I may be able to suggest an app.
Hope that helped!
2answers
No Sound..Missing Multimedia Audio Controller
Go to the toshiba, and download the audio drivers for your laptop.
In the device manager, right click and uninstall the device.
Reboot
Reinstall the audio drivers.
Do it by the downloaded file, rather then the Windows Wizard.
If the downloaded file does not have a setup.exe or an install.exe, go to the device manager, and choose "Update drivers". Point it at the folder you downloaded the drivers to, and let it do the install.
If there is a problem after that, please post any error messages.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
