My dryer will not heat up
More than likely a bad heating element.
Look for a safety control: high limit overtemp or a fuse on the element that you can reset or replace. Ohm out the element to check if it damaged.
You need to take the back off the dryer to access the heating system. Several possible problems. Check the heater back there which is inside the right duct work. Check the small white ceramic thermal fuse with 2 wires going to it. If the dryer got too hot theat fuse will burn out and needs replaced. Check all the other round thermostats mounted back there also. Last possible problem is a bad timer. The heater power is fed through a set of contacts in the timer also. All those things need testing..
U need to check the heating element ,u know how are CALl for service
