Video Game Consoles & Games Logo
Philip Davies Posted on Mar 13, 2015
Is there a site that has action replay codes for the PlayStation 2.
The reason for my question is because datel has shut down their site for the PlayStation 2 pal UK.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Mar 04, 2009
SOURCE: Erased Action Replay
iN YOUR INSTRUSTION BOOKLET, LOOKUP sYSTEM rESTART. fOLLOW THAT AND THEN YOU'LL BE ABLE TO PUT YOUR GAMES BACK ON AS THE DEFAULT SETTINGS BUT IT MAY TAKE A LONG TIME. rE DOWNLOADING THE GAMES.
Anonymous
  • 12 Answers
  • Posted on Mar 28, 2009
SOURCE: action replay code manager doesnt see the action replay
Many are experiencing this, what you are looking at here is a faulty action replay. go to the Datel website and submit your serial number to them, it will immediatly say whether or not your AR is from the time period when they had a problem with the internal USB reading system, if it is, then send it in and one will be shipped withing 10-12 weeks
Anonymous
  • 12 Answers
  • Posted on Mar 29, 2009
SOURCE: my action replay code manager is empty and I want to add pokemon
Heres your problem, I believe you just recently purchased this AR, the new version of action replay require a software update found on Datel's website, after downloading this software your Domain Suffix of your Optical Drive will automatically replace the program with the newer one. Open up your winsock processor and buffer the Native file of your AR back into your fluxus core before adding codes to your action replay, if this does not fix the problem, submit a complaint to the Datel Hacking Team located at PO box 45265 North Ridge, CA. This whole process should take anywhere from 10-12 weeks to fully resolve
Anonymous
  • 73 Answers
  • Posted on Aug 25, 2009
SOURCE: when i try to open the action replay code manager i get this error message Run time error! Program: .. /action replay code manager\actionreplaycodemanager.exe this application has requested the runtim
Its your computer
Anonymous
  • 10 Answers
  • Posted on Sep 02, 2009
SOURCE: My DS action replay is broken
If you hold A B START AND SELECT at the same time, with the power OFF, then turn it on with your thumb or something and let go when it says the product isnt endorsed with nintendo. hope it works good luck =)
PlayStation 2 Action Replay Not Working
the arrow does not appear on the screen why?
My action replay is stuck on saving settings
Deactivate some codes and allow the game to boot as usual. Too many codes overtaxes the cpu, not allowing it to save properly and continue with the boot process.
When ever i start my action replay the screen turns white and it stys like that, how to fix it???
reset the device by right clicking the datel symbol in the corner on the code manager go to about action replay and to reset action replay
5helpful
4answers
Repair action replay
I done this before and it works.
1. Start it up 2. After the "WARNING HEALTH AND SAFETY" (but before the Action Replay menu) Push "A"+"B"+"START"+"SELECT"
That should completely reset it. Happy Fixing :u)
My action replay makes my controller not work ps2
you might want to double check your master code for the game, and check the version of your software too i had the same issue i was using the wrong master code
Whenever i try to put in the pokemon platinum ID code from my Action replay it just shows red and blue lines what do i do?
You may need to reset your action replay like i did when i had the same problem The best thing to do is to save all your cheats to code manager and go on http://us.codejunkies.com/support/article.aspx?article_id=351 this will help reset the ar but all codes still on it will be gone. Hope this helps Xamous
5helpful
2answers
My action replay code manager is empty and I want to add pokemon
1helpful
2answers
Top Datel Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
