Go to Settings, select facebook, press uninstall or update, which option is available to you.
If uninstall, then the App will be uninstalled, after which you should re-install the app by going to App-Store and locate Facebook App there, to reinstall.
If Update, then you should select this option and lets the App update itself and try it Again. If problem still occurs, then uninstall as described above.
Find the icon for the app you want to delete, and press and hold it for a few seconds. It (and all the other icons on the screen) will start to wobble gently, and a small cross will appear in a grey circle by each. Tap the cross, then confirm you want to delete the app.
You download the Facebook Application (App) from the Play Store. Here are detailed instructions:
First Method:
Start at the Home screen.
Tap the icon that is a circle with six spots in it to show all apps.
Find the Play Store icon. The icons are alphabetically ordered. Play Store will be with the other P apps. You may need to scroll the apps page to get to the Ps. Place your finger on the screen between icons and drag to the left or top.
When you find the Play Store icon, tap it.
In the search bar, type Facebook, then tap the magnifying glass icon.
Accept the download.
Second Method:
Open Chrome (or Browser if it's installed.
Type Facebook, to navigate to the Facebook web page.
The web page will recognize that you are visiting from a tablet and will offer to install the app. Tap that link.
You will be taken to the Play Store and the Facebook app will be installed.
Generally speaking, you can fix this by killing the FB app. Double tap the home button. This brings all running apps to the forefront, you might have to scroll to find Facebook. Tip, the displayed app will appear in a floating window, and the Facebook Tile will be displayed center screen when you find it. Now, swipe up to shut the app down. This generally fixes the problem.
Firstly try to double tap your home button to reveal active apps, then depending on your iOS, this next step may simply require you to a: flick upwards on each app to close it, or b: press and hold on an app to reveal an 'x' in the top left / right corner of the active app list, locate the app by swiping left or right then touch on the jiggling app ensuring to touch the 'x' in the top left / right corner of the app. Still no success? Press and hold the power button on the top of your iPad, while at the same time pressing and holding the home button, do not let go as the screen goes blank/black, once you see the apple logo, release them both and allow the iPad to complete its restart. Still no luck? Try removing the app and then re-installing it. Hope this helps.
I'm having the same issue on all my Idevices. Once slotomania was updated from the AppStore you can't login to Facebook with the app. Facebook shows a blank widow and won't allow the login, and the app no longer loads :(. Guess its a Facebook issue. Time to pull out the old laptop and play that way.
