It shows yellow boxes and there is this voice that describe every touch or option i use- Please help !
SOURCE: set top box and remote control
I have the same problem. When I move the 8300HDC away from the TV, or power off the TV, the remote responds. There seems to be some kind of RF interference, which makes no sense since the TV shouldn't emit RF, and the the box should be using IR only for remote input. My TV is a 46" LCD Samsung. Try turning off the TV and see if the 8300HDC responds to powering on and off with the remote.
SOURCE: lg kg800 Chocolate mms set up for T-Mobile
i bought the LG KG00 and all you have to do is call T-Mobile, make SURE YOU ASK FOR SOMEONE IN TIER 2!!!
NO ONE ELSE WILL BE ABLE TO HELP YOU.
anyway, once you do that you let them know, and they will set up your picture messaging for you :)
SOURCE: i need manual settings for gprs
1. Press Blackberry Button
2. Go into Options
3. Go into Advanced Options
4. Select Host Routing Table
5. Highlight top line
6. Press Blackberry Button
7. Choose Register Now.
You should now have the Service Books for your current Service Provider.
Gadget
SOURCE: Bell South 2250 one seems to be voice activated and other not voice activated.
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps.
SOURCE: i can't set up scenner options in aficio mp2000
look here in Ricoh white papers you should be able to find what you need. http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
?GPRS Settings
Nokia
6300
Step 1: Click here to
receive the correct settings from Nokia by sms
Step 2: Follow
the instructions to set up your phone:
1. Go to Menu > Settings > Configuration
2. Choose Personal configuration settings
3. Press Options
4. Select Add new and Access point
5. Fill in a Account name
6. Select Access point settings
7. Set Data bearer to GPRS
8. Select Bearer settings
9. Enter GPRS access point (APN); FOR DOCOMO ENTER TATA.DOCOMO.INTERNET AS ACCESS POINT
10. Set Authentication type to Normal
11. Enter User name and Password if requested
12. Back * 3
13. Choose Options and Activate
14. Go Back
15. Set Preferred access point to the access point you just made.
16. Set Default configuration settings to Personal config.
17. Select Activate default in all applications and Yes.
NOW YOUR DONE YOUR SETTING IS READY TO USE
