I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Pop the back cover off. It's real easy - you can use a credit card or even your fingernails. Carefully prise all around the edges. It'll come off quite easily. Looking from the rear with USB port at the bottom, you'll see the left side if the unit is occupied by a large rectangular battery. At the top right of the battery is a connector with six wires. Gently disconnect the connector from the main board. Leave disconnected for about 30-60 seconds and then plug it back in.
Put the back cover back on, and then plug in the charger.
Samsung galaxy is a powerful device which require at least a 2A charger to charge it well. computer can only deliver 0.5A and thus is not enough power to charge your tablet. Connect it to the wall AC charger that come with the tablet and you'll be able to charge it just fine
