Question about Samsung LN Televison & Video
Increase brightness in samsung tv
Brightness in setting is 1005 but cant get the clear picture due to darkness
    Top Expert:
  • Samsung Master
  • 76,177 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Mar 15, 2015
6ya staff
SOURCE:
How do I lighten a dark picture
Hi Richard,
Please try reducing the contrast a little and increasing the brightness till the dark shots are clear. Please also check the back light setting. It should not be too low.This should make all the dark scenes clearly visible if it only a setting problem. In case the overall brightness has reduced, please consult a local TV Tech.
Aug 11, 2015 | Sharp Aquos Televison & Video
I have a lg 32" tv and have connected everything
Dark picture means you have low brightness on the screen. Please increase the brightness. Also try increasing the back light intensity.
Sep 11, 2014 | Televison & Video
Toshiba tv has dark picture cant hardly see want get bright
If it's a old style projection screen pry off front grid, you,ll see a trapezoidal mirror this often becomes hazed smoke, dirt, ect. Make sure set is unplugged DO NOT ASSUME THEIR IS NO SHOCK HAZZARD BECAUSE SET IS UNPLUGGED(see capacitors) be careful and clean mirror with damp cloth and glass cleaner try not to spray as safety percotion, their are 3 tubes red , green, blue, green is th dominaent color if you know how turn blue HVU UP 1st( CLEAN picture tube lens 1st) These type of picture tube have clear poly glycol ( anti freeze) in lens unit to cool and is part of the optical system. I this fluid becomes contaminated then cost of repair may exceed value of unit, then increase red value I just thought you may bee able to do the color via menu not sure, if picture has a green tent at start this should help good luck , lot me know what you see.
Aug 18, 2014 | Televison & Video
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
What should the picture settings be adjusted to to obtain the best, most clear picture?
That depends on the ambient light and your own preferences. That's why there are different settings. Is the room dark or well-lit or something in between? Do you want the picture bright, or do you prefer it a little darker?
Dec 29, 2011 | Samsung UN46D6050 TV
My samsung lcd monitor have a dim light.. i cant see most of pictures or any thing that has a dark part on it... like pictures, videos
It is possible that the monitor settings have changed. There should be a menu or settings button on the monitor. Try to increase brightness and decrease contrast.
Unfortunately, it is much more likely that your monitor is failing and needs to be serviced or replaced. Given the price of monitors replacement is probably the least expensive solution.
I hope this helps. Good luck!
Mar 26, 2011 | Samsung SyncMaster 17" LCD Monitor
My Samsung DLP HD tv's picture is starting to go dim. What can I do to make the picture bright like it used to be. Model Code - HLS6187WX Thank you for any help you can provide. Spencer
Has the lamp ever been replaced? As lamps age they get darker screens. First though check to make sure the TV settings aren't accidentally on a dark setting. Go into the menu and see if increasing the brightness helps.Different picture modes like movie, games, vivid have different brightness settings vivid usually the brightest.
Sep 11, 2010 | Samsung Televison & Video
Have a lcd 42 dynex picture dark
Have a 40" Dynex LCD TV...Has been workin ok but i just turned it on today and pics are dark and yet all pics settings are ok. Pics are still dark even when i increase brightness from menu.
May 18, 2010 | Televison & Video
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
